ajriding
Dec 04, 2017Explorer II
Holie roof
I found the leak in my roof. It is aluminum and there is what looks like rust holes. I taped over them with duct tape for now. It seems to be just the front right quadrant affected, the rest of the...
SidecarFlip wrote:
Wood does rot when wet (and enclosed and light tight). What happens to RV's they rot. The reason why your aluminum roof perforated in the first place was water under it and the water coupled with the mold, attacked the aluminum from the underside causing corrosion and your hole issues. It corroded from underneath not from the outside.
