MFL
Jan 07, 2019Nomad II
Atlee wrote:
Question #1: How do you put gas in the bottom generator?
Question #2: Can an extended run external tank be connected to both of those generators?
It's easy to do with Hondas. Can it be done with Champions?
They can be run/paralleled side by side, if you wanted to use an extended run tank. You may be able to add fuel to the bottom tank, with the supplied funnel, if you did not want to lift it off.
If you are refueling in the dark, this Champ has a built in LED light, that shines right in the gas tank. Nice little feature IMO!
Jerry
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
