path1's avatar
path1
Home made Jumper cable question
The clamps on my old jumper cables were shot so I ordered new ones. When the new clamps arrived I cut off old ones and was disappointed to see the wire in my old cables were so small. My old wires were about 16 gauge and about 8 strands. And only about 8 feet long. So I looked at getting new cables and I see a "good" set of cables aren't cheap.
Yesterday at a surplus metal store I saw some type of cable (alum) I think, made up of maybe size 14 or 12 and about 10 or 12 strands making up the cable. Being I already have new clamps for the ends, I was thinking about getting the cable. I could slide new cable into a hose. I would make them long enough so I could park in back of somebody's car and reach their battery from mine. Cable is flexible enough.
Including the clamps about $60.00 total into project for what I think will be nice set of cables.
But just sounds to easy....and anything elec I always double check because elec not one of my better subjects.
Please tell me what I'm getting ready to screw up?
  • Since I bought a good battery jump starter/air compressor/flasher box I haven't used cables. I carried them around just in case for a year or two. Then finally left them in the garage. Newer battery jumper boxes are truly powerful and reliable. I've jump started everything from my back how to my old 12valve work truck. I've used it for my dump trailer, I've aired up countless tires. Best $ ive ever spent.
  • Do not have a set myself, but have used ones made from welding cable many times. By far the best you can get. Welding cable is designed to carry a lot of current, and still be very flexible.
  • I make mine out of #4 welding cable available at welding supply houses. 25 ft. is about $40. Crimp AND solder to a good set of clamps and you are good to go for a long time. I make mine about 15 ft. long.
  • Good job on a diy solution that fits your needs.
    Not sure where you looked online but aluminum jumper cables are really cheap even in massive gauges.
    Pure copper cables on the other hand, the prices remind me of the days when copper was considered valuable.
    The arm chair attorney in me won't jump anyone elses' vehicle, too much liability if someone was injured or property damaged.
Having RV issues? Connect with others who have been in your shoes.24,193 PostsLatest Activity: Jan 27, 2025
