The 30 amp circuit is 110/120. It is a 30 amp breaker in my home entrance, that is wired just a short distance to my compressor, with a normal 2 outlet plug in.
The electrician just used a 12 ga wire to the outlet, about 10 feet.
Is there a heavier dogbone that I could buy, such as 30-30 or 30-20? I have only seen the 30-15.
I normally just plug in for charging the battery, and using the fridge on electric, when getting ready to go camping, otherwise I'd consider putting in a proper RV outlet.
Thanks for your reply pianotuna!
Jerry
