- wa8yxmExplorer IIIIf you ask the manufacturers they will always say "Same Same Only"
NOt only do not mix a Honda with a ____
But do not mix a 2000 with a 1000 (Though people do it often)
or to be more general an x000 with y000
I'd listen to the folks doing it. I would not recommend it (liability reasons) But I'd listen to the folks doing it. - 2oldmanExplorer II
jdc1 wrote:
Yep. Works for me.
The good thing about YouTube is you can actually see something done, and running. Then you can make your own assumption.. - jdc1Explorer II
2oldman wrote:
Youtube knows everything.
The good thing about YouTube is you can actually see something done, and running. Then you can make your own assumption. Like the saying goes "Seeing is believing." These videos I saw about pairing different generators pretty much validate what can be done, unlike someone here saying it can or can't be done. - 2oldmanExplorer II
3 tons wrote:
No, you can use any of their generators. I have, including a 2200 with 2 2000s. Now I'm doing two 2200s and a 1000. It all works, provided it's all Honda. Pairing with another brand.. dk.
With Honda, to parallel it appears you have to use their ‘companion’ generator, and according to the manual, paralleling a 2200 to a 2000 is not allowed… Personally, I have zero interest in putting at risk my pricy 2200 via an off-brand parallel experiment, but hey thats just me :)
3 tons
But hey, it's the internet, so don't trust me. - 3_tonsExplorer IIIWith Honda, to parallel it appears you have to use their ‘companion’ generator, and according to the manual, paralleling a 2200 to a 2000 is not allowed… Personally, I have zero interest in putting at risk my pricy 2200 via an off-brand parallel experiment, but hey thats just me :)
3 tons - wing_zealotExplorer
- road-runnerExplorer III
2oldman wrote:
I took that as a good reminder to be cautious of claims on the internet. Too many people post their best guess or opinion as fact.
"If it's on the internet, it must be true" - road-runnerExplorer IIIIf they are both inverter generators there's a chance it could work ok. There's also a chance of damaging one or both of them. If somebody else has actually paralleled the exact models you're thinking of, your risk is greatly reduced. Since the Honda generators have a higher normal output voltage than most others, I'd expect the Honda to carry almost all the load until it approaches its maximum output, then the other generator would carry the additional load. This unless the Westinghouse generator is also on the high side, output-voltage-wise.
- GdetrailerExplorer III
2oldman wrote:
Youtube knows everything. - 2oldmanExplorer IIYoutube knows everything.
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 22, 2025
