BFL13
Aug 15, 2015Explorer II
The Honda 1000w can run about a 45 amp non-pf corrected charger, so it is unlikely to be able to run a 50 amp charger. (who has one of those?---most go from 45 then jump to 55 or 60)
Since in Canada the Honda 2000 cannot be paralleled but the 1000w can, your choice is to get a second 1000 or a single 2000 depending on scenarios. Two 1000s will do more than a single 2000 because of their VAs)
Many find that their WFCO is unsat (won't do boost or float). You might be replacing it with something better so you want your gen to be able to run whatever you get to replace the WFCO.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
