RoyB
Aug 15, 2015Explorer III
Looks kike the WF8955PEC is rated at 960WATT Input 120VAC.. I suspect all you will be able to get out of the Honda is probably around 800WATTS maybe 850WATTS...
AMAZON WF8955PEC SPECS
You will also no doubt have more things running in your trailer when you connect the trailer shore power cable to the Honda 1KW in order to run the WF8955PEC unit.
Gonna be short I think...
Also everyone I know replaces the WF8955PEC unit as soon as they get it... These units are notorious for not going into SMART MODE CHARGING voltages no matter what you do to them,,,
If the WF8955PEC only puts out 13.7VDC then it will take over 24 hours to bring a 50% charge state battery to 90% charge state.
Most likely where you will be camping will have generator run time restrictions in place and no way will you be allowed to run a generator 24 hours straight...
Got to get what you need to do the minimum time re-charge a 50% charge state battery which is three hours time...
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
