MrWizard
Aug 15, 2015Moderator
I was told it was a 50 amp but I just went and looked and it is a 55amp charger. 8955PEC is model. I guess way more then what a 1000 watt can handle. When you say it won't do boost or float are you saying that it can't charge at near 50 amps? I never plug in this rv I let the solar charger do the battery charging at home (zero shade) my concern is near dead batteries after 2 nights of furnace use in winter with sun so low our trees around here block all sun. I guess the 2000 watt is the better choice.
when you get a generator, you will be better off, IF you charge every day,
don't let the batteries get that low, if it can be avoided
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
