Dirtpig
Aug 16, 2015Explorer
pianotuna wrote:
No one in their right mind would attempt to fully charge a battery bank by running a generator, unless they have no choice. Acceptance rate becomes about 12.5 amps per 100 amp-hours of storage at 85% state of charge. Most folks charge from 50% to 80% and call it good. Then when they have shore power the bank gets fully charged.
You may be a candidate for a solar system if all you wish to do is charge the battery bank.Dirtpig wrote:
This is very good info, thankyou everyone. I will check the voltage of the batteries the next time i plug it into power when they are down 50% and see what the voltage goes up to. I would only want to run the gen for an hour or two so if its going to take up to 24hrs to recharge then i will definitely need to upgrade that converter.
I have a 300 watt solar system with a bluesky 30 amp pwm controller which I set the absorption voltage to 14.8. I have 2 trojan t-105. Reason for wanting a generator is to get through 3 nights of camping in winter time. Ideally I'd like to only have to run it a couple hours a day. My battery usage is low. The furnace is biggest sucker of batteries (0-6deg Celsius outside in winter). Unfortunately the solar does nothing for me in winter months as it is usually dark clouds or trees will block out sun.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
