RJsfishin
Aug 16, 2015Explorer
Heres what I can tell you for sure,....
My eu1000 would trip out on a PD9155 running full 55 amps...I had to grab a lower gear on the wizard.
It works hard for a few minutes on a PD9245 running full 45 amps, but doesn't trip out.
If you change out to a PD 45 amp, the 1000 will do it, and still be much faster than the WFCO
If you change out to a PD9260 w/ pendant, you will still be ok w/ the 1000, but you may have to drop a gear on the pendant for 5 minutes,... if the batteries get very low.
Considering the weight and size difference, I'd choose the 1000 if possible.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
