road-runner
Sep 30, 2015Explorer III
If you comb through the archives you will find posts from numerous RVers routinely running a 13,500 BTU air conditioner with the eu2000i, more often than not a Dometic Brisk Air. Success with other brands is low. You'll also read that either the air conditioner will burn up from low voltage, even though it's 115 or higher, or the generator will burn up, even though the running power draw is comfortably under the generator's maximum continuous rating (with the Brisk Air). For success you definitely have to manage the AC loads, and don't rely on it at higher altitudes. Best to monitor the running voltage. If it's at or near 120, you're IMO not abusing the air conditioner or the generator. Just have to see what works for you.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 17, 2026
