lawrosa
Oct 11, 2015Explorer
However, to imply that an EU2000i is operating at 100% when powering ANY 13.5k BTU a/c at sea level is simply incorrect.
Thats right. It is simply incorrect and here are hard #'s
Well I took some readings.. This honda 2000 starts the 13.5 duo therm A/C no problem..
Plugged into killowatt meter. Turned off converter charging side.
( converter was showing 3.19 amps /172 watts draw trying to charge the batterys hence why I turned off the charging side. That 3 amps could be the factor starting the a/c. Once a/c was started I flipped the convertor back on, Gen ran no problems.)
With a/c running gen shows 124.2 volts output. ( 126v with no laods)
9.19 amp draw with a/c running..
1005 watts being drawn... Not bad. Alittle more then 50% capacity of the gen.
Right at 60 hz...
Its also the quietest gen I ever heard...
With that said it would be nice boondocking as we had this summer in 90f plus weather to be able to cool down the camper mid day...
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
