Bobbo
Nov 23, 2022Explorer III
C Schomer wrote:
Bonding worked! My 5er required bonding and so does my home Armstrong furnace so I opened up the Honda panel and bonded neutral/grd. permanently.
I always run my gen on eco throttle so it only runs at the rpm necessary. I ran my furnace on hi blower and the Honda stayed at minimum rpm... it hardly noticed the small load. My UEI amp-clamp bit it, so I couldn't get the amp reading.
BTW, UEI is throwaway junk. I'm going back to Fluke. Craig
Thank you for the feedback.
3 tons wrote:Grit dog wrote:ROBERTSUNRUS wrote:
:) My furnace, HVAC system, runs on 240 volts. So my generator won't run it either.
My furnace is a woodstove. My Honda doesn't do much for it either....
Relevance?
OMG, just think of all the plant fertilizer (CO2) you’re pumping into the atmosphere!!
3 tons
As if the Honda doesn't generate any?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
