austinjenna
Oct 09, 2022Explorer
austinjenna wrote:
So forgive my lack of electrical knowledge but is all that I would need to do is get a 110 plug, then run a small jumper from the ground to the neutral(white/silver) side of the plug and plug that into the generator?
My assumption is that instead of using a 110 plug I could also do it for the 30 amp outlet on the generator and therefore free up a 110 outlet. My genny has 2 - 110 outlets and 1-30 amp outlet
Thanks
For 5 years, I have been using a bonding plug, exactly as you describe, so my PI EMS will let my Honda EU2000i current into the trailer. I finally got tired of fooling with the plug this summer and opened up the Honda's faceplate. I jumpered the GROUND to the NEUTRAL on the Honda's receptacle, itself. So, yes, you can jumper the back of the 30 amp outlet. Or, if it is easier, jumper the back of the 15 amp outlet. It doesn't matter which outlet you jumper.
A few weeks later, I came across another camper who was complaining about having to disable his PI EMS when running his generator. I gave him my (now unneeded) bonding plug and told him to plug it INTO THE GENERATOR, ITSELF.
Thanks. I have an EU2000 and it does run my house furnace and have done that when the power has gone out in winter. I was curious about this for my daughter who will be getting a new furnace and has a ryobi inverter generator and being able to set her up and what might need to be done.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
