wnjj
Apr 03, 2009Explorer II
capterik wrote:
Only thing I would add is to do this when you put it away instead of waiting, as shapeshifter found out, when he needed it it didn't work. Great writeup.
Unless you drain the gas or use fuel stabilizer, it won't do any good to clean it before you put it away. Mine had problems because I put it away and the gas went bad. It was running perfectly when I had used it previously. In my case the carb cleaning was needed to get it running again.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
