MrTravelDecal
Jan 30, 2010Explorer
h45wt wrote:
I believe that there is a fuel filter inside the fuel tank as well as the tubular screen in the filler neck. I'd like too change the inside one but haven't been able to figure out where it is. Anyone ever changed it?
I know this is way late but OF COURSE there is a filter in the tank!
You will need to pull the fuel line off of the bottom of the tank. Inside of the little moulded nipple of the plastic tank (that you just pulled the fuel line from) you will find a long and skinny fuel filtering screen. It is no larger in diameter than a pencil. probably a bit thinner actually.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
