Matthew_B
Jan 30, 2010Explorer
Atchafalaya_man wrote:
a) Gasoline and Water will not mix. Water will puddle in the gas container.
b) Gasoline and Alcohol will mix. No puddle.
c) "Water and Alcohol" mix too. No puddle.
ONCE THEY HAVE MIXED;
d) Gasoline will mix with "Water and Alcohol" , resulting in:
UNSEEN WATER MIXED IN YOUR GAS!
I doubt if any engine is designed for this mix (d), so don't give it to your engine.
Only a little bit of water can be in solution with gasoline and ethanol. After it saturates the alcohol will come out and you'll have puddles of alcohol and water under the gasoline. Methanol is much better at mixing them up. That's why dry gas is methanol and not ethanol.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
