mchero
May 27, 2010Explorer
Sidney
EU1000 genset is slightly different. The car cleaner assembly does not remove like the EU2000. You pull the two nuts holding the ductwork from air cleaner to carb & remove. It connect between the Air Cleaner and carb. Once that's removed you have to carefully remove the fuel line. You can then remove the carb. Looks exactly like the EU2K.
I have had my EU1K case stripped down a number of times. Hard part is routing all the cables properly.
I'll be doing a similar writeup on the EU1000. Carb & electrical diagnosis on my writeup.
SidKaye wrote:
Ron, thanks for a great post. I have a EU1000i, do you know if the procedure would be the same or similar. Mine has been running rough on ECO and jut today I was searching the net for carb maintenance.
Sidney
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
