bigfootford
Mar 18, 2011Nomad III
CMH wrote:
I am still having problems with my 2000. I have cleaned the carb, Sea foamed the fuel tank, and fresh fuel. I have to run it with 1/2 choke and it will only run for about 5 mins or so. Any suggestions?
You have to remove that emlusion tube and clean it. That's where the debris will restrict the fuel and lean out the motor.
That little tube is right under the jet (screw). It sometimes is difficult to get out. You will see the small holes for the fuel, they will plug up. You can not clean this tube while it is in the carb, you have to get it out. Be careful if you use a blast of air from some of the ports of the carb. The tube can come out flying!!! I nearly lost mine the first time I did it.
Jim
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
