bigfootford
Jul 06, 2011Nomad III
Almostthere wrote:
Good review and procedure for cleaning carb jets on Honda. However, how do you get the jet out if it does not "fall" out once the threaded plug is removed. I gently tried to use a welding tip cleaner to get it to drop out.........no success. Obviously you need to be careful not to disrupt the orifice in the jet.
quote=tomatillo on 07/02/11 01:39am
HELP -- I removed eco throttle control before reading this post and sticky!
How else are you going to soak the carb!!? That thing has to come off, of course. I even have an online manual - after hours of searching -- and it mentions nothing about how that blasted thing goes back on!
I used my compressed air, and blew into the various fuel pickup holes in the float bowl. I blocked the various other fuel outlets in the venturi area with my hand. The Jet popped out. Be careful when you do this...You could loose the jet.
I did not soak my carb. I just used spray carb cleaner and brake cleaner.
As for the re-install of the throttle control I just put it back on.
If you are still having trouble maybe someone can help ya...
Jim
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
