bigfootford
Dec 17, 2012Nomad III
Reddog1 wrote:
If I underestand correctly, the tube you want to remove is piece 12 (NOZZLE, MAIN (Honda Code 6727770) in the carb break down. If true, did you remove the piece 32 (JET SET, PILOT (#35) (Honda Code 1441609)? With piece 32 removed, you can insert a flat screwdriver in the throat of the carb, and using the flat side of the screwdriver, push the piece 12 down.
When looking at the diagram, find the top of 12 (emulsion tube) that tip will protrude into the inside of the venturi/throat of the carb..Remove 31 (jet) with a screwdriver. Just use the flat part of the screw driver and push 12 from the inside of the venturi. ..It will slide out enough to pull it out where 31 (jet) was screwed into.
Jim
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
