bigfootford
Dec 17, 2012Nomad III
dreamco wrote:
That's exactly what I tried to do...I was pushing down pretty hard on the little nipple protruding through the main throat and I still couldn't get it to move. I wasn't sure of how much pressure to apply.
Ummm....guess I would try pb blaster or wd40, let it soak....
Push it back in and then back out a bunch of times, spraying a bit as you do it and see if it will free up...
Would hate to see you damage the tube but that may be your only recourse. Or do what Wayne said.
You do not want to damage the tip that goes into the venturi area... You may not get it out....So pulling it is the thing to do after you have it sticking out from the jet end if possible.
What I saw with Wayne's (Reddog) was that it had corrosion from water on the tube...So that may be the same with yours...
Jim
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
