dreamco
Dec 17, 2012Explorer
bigfootford wrote:dreamco wrote:bigfootford wrote:dreamco wrote:
There is definitely no grey on either end of the tube that I can see...it appears brass color with no discoloration at all. The generator is only 2 years old with very minimal use. I'm really surprised that this tube is as seized as it is.
Me too!
Can you push it back in and out despite being a small amount?
Jim
No, the tube hasn't budged a millimeter
Oh, I thought it budged a bit at first....
Was the jet, 31 tight/hard to remove?
If you place the a screwdriver blade flat on the end protruding into the venturi area to keep from damaging/flattening it and then use another screw driver to use as a lever that might work, keeping the other driver flat on the end of the tube...
Never seen that tube stick like that...
We do have an active member that is a Honda tech...Wonder if someone can rouse him....I don't recall his name. I will look/search and see.
Jim
Ironically the main jet (#31) screwed right out without issue.
I'll try your method with a couple of screwdrivers and see how that works.
Thanks for all the help Jim....greatly appreciated!
Wayne
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 06, 2026
