dreamco
Dec 28, 2014Explorer
bigfootford wrote:dreamco wrote:Reddog1 wrote:
You still have some garbage in the carb jets.
Wayne
MAN!
They were full of junk too...I used my micro drill set to clean out all the holes in the jets then sprayed them with carb cleaner, then blew high pressure air through them just as I always do...I'll repeat steps...haha.
Thanks Wayne!
Wonder how all that ended up in your jets?
Usually we find that there is just a small, small piece of******in there....
You should have seen lots of******in the float bowl if you were observing a "full of junk too" thing!
You did remove the emulsion jet? That is the normal culprit.
Jim
Well, I just repeated the process and it worked perfectly! I'm all good. Jim, when I say junk I'm referring to the chalky tarnish residue. Nothing really abnormal.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
