Reddog1
Dec 29, 2014Explorer II
Thanks Jim.
After all this time, I cannot say the filter for a water trap is a major reason to install the filter. Only one time can I honestly say I had a substantial amount of water in the filter. I made the mistake of filling the tank with fuel from a 5 gallon can that had been sitting for a while and was almost empty. I know better than to pour the last drop from any fuel contained. Just asking for trouble. I have had to remove garbage from the filter.
I think the loop in the fuel line is a big plus. I have seen syrup looking stuff in the bottom of the loop. I still wonder how it gets past the filter.
I do not recall having to remove and clean out my carburetor since I have made the filter modification. I made the mod in such a way I can remove the mod by loosening two hose clamps and reconnect the OEM hoses. If I ever open it up again, I will remove the OEM filter from the fuel tank.
I have added a fuel shutoff, but never use it. I have also added a piece of tubing from the bottom of the air cleaner to the bottom of the Honda, beside the float bowel drain. When it is exceptionally cold, and/or I have not started the Honda for a while I can easily give it a snort of starting fluid by simply spraying in to the tubing. No need to remove the front cover.
Wayne
Wayne
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
