malgal
May 19, 2015Explorer
Thanks for the great post. I usually do this when I put my genny away for the winter.
Today I got it out again, and it started like a dream, as usual. I ran it for about 30 minutes under load. When I lifted it up to put away I noticed a small puddle of gas underneath. I took the side panel off and started it up again. The leak appears to be coming from the joint between the air filter and the carb body. I looked at that gasket and it seems to be ok. I then removed the float chamber in case it wasn't properly seated and made sure it was ok and put it back. Started again and still leaking.
I wouldn't have expected there to be that much fuel in the carb throat. Any suggestions?
Dennis in Las Vegas
Dennis in Las Vegas
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
