scootsk
Jan 12, 2016Explorer III
Mobile sport wrote:
Unbelievable ,, I took my carb apart and it looked clean as could be , didn't think cleaning it was going to work but I went ahead and bought some carb cleaner , I sprayed it through all the holes and soaked the jet for a couple hours , made sure everything was dry and put back together.
Fired it up and I couldn't believe it kept running !!!!!!
Thanks AISurffish
Forgot to mention , man that was easy , I don't use the red Honda case so basically unbolted the air filter , slide off the carb ,
Disassemble carb , spray , assemble.
Just curious, why don't you use the red Honda case? Your entire case is removed? Is there an advantage to that? How is the noise level?
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
