mikestock
Jun 20, 2013Explorer
CentralCoastCampers wrote:
Don't mean to hi-jack the thread, but could you use 2 2000i and 1 1000i? Would this help with the A/C start-up surge when in Eco mode? Main reason I ask is I already have those, and don't really want to buy another 2000i.
That should work. Surge capacity of 5000 watts and run capacity at 4000 watts should keep two ac's running if they don't try to start at the same time.
Where did you find the banana plugs that are shielded like the ones from Honda? What are the black components the black wires go into on each side if the interior of the box?
Polarity of the wires doesn't matter. If you want to build your own box you can buy these, cut the cables in half and wire your own box.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
