Lynnmor
Feb 02, 2017Explorer II
2oldman wrote:
i don't know what 'fog them' means, but how does a generator start on the 1st pull when it's been drained of gas?
Obviously the carb needs to be filled with gas before it can start. A local Honda dealer tells buyers to fill the tank, close the vent, then rock the generator side to side. This agitation will build a bit of pressure and push gas into the carb. To test this theory, just shake a closed gas can and then listen for pressure venting as it is opened.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
