- Thunder_MountaiExplorer II
samsontdog wrote:
I run mine out of gas or drain the gas out of the tanks then I drain the gas out of the bowl. Good for months
at a time. They start on the 2nd or 3rd pull
Got a pair of Hondas that are over 10 years old. I do what he said. And yes, they start up on the 2nd or 3rd pull each spring! - ScottGNomadI drain the carb and make sure there's plenty of Seafoam in the tank - 1/4 to 1/2 a can.
This has actually made it run better than when new. - samsontdogExplorerI run mine out of gas or drain the gas out of the tanks then I drain the gas out of the bowl. Good for months
at a time. They start on the 2nd or 3rd pull - BFL13Explorer II
2oldman wrote:
I forget, so I have to read the manual.
If it is not on line it does not exist! :)
If it takes more than two clicks on line it does not exist! :) - 2oldmanExplorer III forget, so I have to read the manual.
- agesilausExplorer IIIDrain the carburetor! Probably drain the fuel tank as well.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
