352's avatar
352
Honda 2000I inverter generator question
How do you prepare your generator for storage for more than 3 months?
  • samsontdog wrote:
    I run mine out of gas or drain the gas out of the tanks then I drain the gas out of the bowl. Good for months
    at a time. They start on the 2nd or 3rd pull
    Got a pair of Hondas that are over 10 years old. I do what he said. And yes, they start up on the 2nd or 3rd pull each spring!
  • I drain the carb and make sure there's plenty of Seafoam in the tank - 1/4 to 1/2 a can.
    This has actually made it run better than when new.
  • I run mine out of gas or drain the gas out of the tanks then I drain the gas out of the bowl. Good for months
  • 2oldman wrote:
    I forget, so I have to read the manual.
    If it is not on line it does not exist! :)
    If it takes more than two clicks on line it does not exist! :)
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
