will a Honda 3000 run a small window unit and a refrig? Thanks I don't have time to look it up, I know there are some here very knowledgeable on the subject right off the top of your head. thanks
The way I deal with big loads is turn ECO off, start AC and then add other loads. Once everything runs nice, turn ECO on. Than you have to make sure AC will not cycle off/on (thermostat all the way down) unless you are around to start the procedure again.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
