- JamesJudasPriesExplorer
stevenal wrote:
JamesJudasPriest,
What brand/size AC do you run?
Im not sure to be honest. Its a dometic duotherm, on my class b 1990 Dodge rv.
1 day after full professional repaint!
- marcsbigfoot20bExplorer
3 tons wrote:
On our last outing in the hot Nevada desert at 7,400' the Honda wouldn't run the 11kbtu AC with the converter being on...
No kidding, -3% power loss for every 1000 feet above sea level.
So 7500 is 7.5 X 3 = 22.5% less power.... Not factoring in hot temps.
That is 1240 watts running or 1550 watts surge. Add in anything over 80 degrees and it's even less. - jalichtyExplorerI have been lead to believe that it would take about 2,700 watts of surge to start a 13,500 AC and certainly a Honda 2000 or Yahama 2000 would not have 2,700 watts of surge. I tried to run my 13,500 AC using my Honda 2000 and it, indeed, would not start and the Honda died. However, we live at 5,000+ feet altitude and it was a pretty hot day. I was not upset at the Honda not being able to run the AC as I never thought it would, just wanted to find out for myself. However, when I parallel the old 20 with the Companion 2000, it starts and runs the AC just fine. I suppose that at lower altitude, somewhat lower temps and with some playing around with the AC, a 2000 would run the AC, but not here at altitude and higher temps. I really like my Hondas, but I also liked my friend's Yahama but they are both pretty expensive compared to the other smaller gens out there.
- stevenalNomad IIIJamesJudasPriest,
What brand/size AC do you run? - 3_tonsExplorer IIIOn our last outing in the hot Nevada desert at 7,400' the Honda wouldn't run the 11kbtu AC with the converter being on...
- road-runnerExplorer III
Huntindog wrote:
What amazes me, is that is is a very old design. I believe it was the first to market and has been in continuous production without any major upgrades... And yet the "new" competition still can't beat it.
This is one thing that they got right the first time.
X2 on that! I've had my eu2000i for a bit over 12 years. For it to not have been leapfrogged by newer technology is very unusual. - HuntindogExplorer
road-runner wrote:
I have the little Hondas.. They are the standard that all others try to match.If it has the " the best surge capability of any inverter genset in this class" then how do you explain it not running a (13.5) A/C when others will....
Perhaps you've already done this, if you don't run the comparison test at the same time, same place, with the same air conditioner, the results don't have a whole lot of value. Altitude, atmospheric conditions, and the make/model of air conditioner are all variables that need to be controlled for a valid conclusion. I have an eu2000i, and I and others on the forum from time to time say the 30 minute 2,000 VA capability is bunk. Maybe at sea level on a cold day, but in real world conditions of mild temps and a few hundred feet of altitude, my observation is that they max out at about 1,900 VA, and won't produce 2,000 VA for any period of time greater than a few seconds. That doesn't mean I'm down on the eu2000i. I haven't heard of a 2,000 VA generator that's better, and the eu2000i seems to be head-and-shoulders above the other 2,000 VA gens in load starting capability.
This is one thing that they got right the first time. - road-runnerExplorer III
Perhaps you've already done this, if you don't run the comparison test at the same time, same place, with the same air conditioner, the results don't have a whole lot of value. Altitude, atmospheric conditions, and the make/model of air conditioner are all variables that need to be controlled for a valid conclusion. I have an eu2000i, and I and others on the forum from time to time say the 30 minute 2,000 VA capability is bunk. Maybe at sea level on a cold day, but in real world conditions of mild temps and a few hundred feet of altitude, my observation is that they max out at about 1,900 VA, and won't produce 2,000 VA for any period of time greater than a few seconds. That doesn't mean I'm down on the eu2000i. I haven't heard of a 2,000 VA generator that's better, and the eu2000i seems to be head-and-shoulders above the other 2,000 VA gens in load starting capability. - drsteveExplorerWhat brand and model was the "other"?
- horton333ExplorerIf it has the " the best surge capability of any inverter genset in this class" then how do you explain it not running a (13.5) A/C when others will..... Did you exclude the cheap ones to establish the 'class' or limit the class to only ones with a highly specific power rating or _____.
Anyway this is sounding too much like people in love with a brand, as opposed to buying a tool with pros and cons which is where I am coming from.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
