SoundGuy
Jul 08, 2016Explorer
aaarneson wrote:
Is there a way to find out what size is in there when I take it out....any identifiers?
Although I've owned 2 different EU2000i gensets I can't answer your question as I've always used the stock main jet which is 0.62 mm (#62), good to 5000'. Between 5000' and 10,000' Honda recommends the next smaller main jet which is 0.60 mm (#60) and for above 10,000' a 0.58 mm (#58). If these jets are marked I'd think you'd find them stamped #62, #60, or #58. Nonetheless, available engine power will still degrade as elevation rises above sea level, with an estimated 25% loss in power at 7200'.
