Donnoh wrote:
ktmrfs wrote:
And the honda 2000 is NOT rated for 2000Watt output, but 2000VA. For resistive loads like a toaster, lights, absorption fridge 120V element etc. VA and WATTS are for all practical purposes the same.
Yes, the advertising says 2000W, easy for marketing to say, but not always the case, especially for RV use.
For loads like microwaves, converters etc. they are NOT the same. The VA draw can be as much as 30% or more higher than the Watts consumed. What that means is that the 1200Watt microwave may draw 1600-1800 VA pushing the limit on the honda if a few other things are turned on as well. (like the 300W from the fridge on electric).
Just something to keep in mind if the generator goes into overload and you think your well within the output spec's of the generator.
I'd like for you to explain your logic on this. VA is volts*amps which is watts. Yes, a microwave may have a rating of 1000 watts output and with losses require 13-1400 watts input, but what does that have to do with anything?
volts x amps= Watts is a special case condition for determining power and only applies to a pure resistive load connected to a DC source or a pure resistive load connected to a sine wave AC source (power to your house or from inverter generator) where the voltage and amps are expressed in a RMS value.
Determining power draw for all load cases is a 1 semester course in Jr. or Sr level college power engineering. And it involves lots of calculus and vector math. (giving volts and amps a amplitude and phase)
That 1000W microwave that consumes 1400Watts of power may actually consume around 1800VA. so instead of drawing 1400/120= 11.6A it will actually draw 1800/120=15A.
Power companies HATE loads like this, they need to supply you with 15A but only can charge you for drawing 11.6A.
And your/my little honda hates it as well since it has to deliver 15A, right near it's rated current, instead of 11.6A.
and then you scratch your head when the generator overloads with the 1400 watts from the microwave and 300 watts from the fridge element, and you say, well that 1700 watts, should run ok, but it trips right away. Well your actually drawing 1800+300=2100VA above what the honda 2000 can deliver at peak output.
Unfortunetely, few mfg state what the VA draw is on devices, so it is often hard to figure out actual load.
but the handy Kilo-watt meter will give you the VA and Watts for a given load. handy device to have.
