Chris_Bryant
Jun 22, 2015Explorer II
1L243 wrote:
After following this post I got up and cleaned both AC's and inside filters... A few dust bunnies and spyder webs but no real dirt. Did a good job cleaning the covers though!
One thing about the Carrier that is fairly unique- the condensation is piped out to the condenser, where a "slinger ring" fan picks the water up and throws it on the coils. In very humid areas, it can grow a sold block of slime- in moderate climates, the moisture makes the fins trap dirt pretty well. To clean, or even see this, you must take the thing apart quite a bit on the roof (shroud and shroud around condenser).
While all air conditioners should be cleaned regularly, the standard height Carrier is particularly bad because of the condensate.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
