pianotuna
Apr 09, 2017Nomad III
Hi,
The remote does not limit the inverter output. But it is 3000 watts or about 25 amps @ 120 volts. That should be ample for any microwave.
My microwave is 1591 watts so it draws 160 amps @ 12 volts. You need good thick cables and a large battery bank for it to work well.
Slownsy wrote:
OK thanks. it's the Magnum MSH3012M and we have the remote which is set for 30amp so will try the change this. The generator is not easy to get to so used the inverter for microwave. If wanting air in future will start generator before using any large load.
Thanks
Frank
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
