dougrainer
Jun 06, 2016Nomad
Devocamper wrote:cruiserjs wrote:
But - it will "freeze" up and not work until ice is gone!!
only if it is low on gas,
IF it is low on Freon, then the odds are it will NOT freeze up much longer. They only hold 16oz of GAS. So if low, you have a leak and after time, that leak will leak enough to render the unit not able to cool much less freeze. A mechanical controlled AC tstat will freeze on LO/COOL setting with a properly charged unit. Wall tstat type units have freeze controls and if functioning the unit will not freeze at all. Doug
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
