Old-Biscuit
Oct 21, 2015Explorer III
Yes you need a jumper wire between RC & RH.........Green wire
You can install the mini switch BUT HIGH Speed Fan will work best.
Low Speed Fan can cause 'icing' issues in high humidity
Low Speed Fan doesn't move much air....... and noise level is about same as High Speed Fan
Whether you want low speed is your choice.
As wired you will get High Speed Fan
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
