Timh1995's avatar
Timh1995
Honeywell thermostat to replace duotherm thermostat
Hi there. Recently we decided we wanted to upgrade the thermostat in our rv and I was reading online it wouldn't be too hard to install a home thermostat. So far it's kind of working. I'm able to turn on the heat and it does toggle on and off the problem is I don't have either the low speed or high speed fan wire attached. When I do and I turn on the heat the ac vent on the roof turns on. I have the switch on the thermostat set to auto but it doesn't matter. So for the time being I just have the low speed fan wire off the thermostat since it's still cold out. Any idea why when I turn the heat on the vent on the roof comes on? The old model thermostat is a duotherm 3107612.008 and the honeywell I picked up is a honeywell rth111 and I have the toggle on the back of the thermostat set to electric-hwat pump and set the advanced settings on function 5 to setting 3 which is heat pump, hot water or high efficiency furnace.
  • Ok so after switching it to gas that fixed it. My bad thanks for the help guys.
