BurbMan
Jul 25, 2014Explorer III
WyoTraveler wrote:
BTW this problem is more common than many think. The 30 amp plug for RVs is the same plug that many 220 vac name brand welders use. Unless you wired it yourself you would never know. In fact I have one wired for my welder mounted by the door of my shop.
IF that is true then you are using the wrong plug on your welder. The NEC specifies different prong configurations for amp/voltage combinations. You should never be in a position of looking at an outlet and wondering if its 110 or 220.
Having RV issues? Connect with others who have been in your shoes.24,402 PostsLatest Activity: Jul 30, 2026
