cyberhuff's avatar
cyberhuff
hooking interior lights to charge controller
I have a pro star 15 amp charge controller hooked to my house batteries and solar panels. The charge controller has seperate terminals for a load.
Im in a chevy g-20 van that has a ceiling mounted fuse block with switches that control the overhead lights, as well as switches for tv and video game (which are disconnected).
I just bought LED replacement bulbs for the overhead lights and they work great but they run off of the van battery.
Can I disconnect the load from the van battery to the fuse block and connect the load out from the charge controller to the fuse block so that my overhead lights run off the house batteries? Or do I connect the fuse block directly to the batteries which are connected to the charge controller and inverter?
Any feedback would be appreciated....thanks
  • Hi Rich,
    On mine, the load terminals only do 2 amps. On a newer version of mine they do up to 20 amps. Read the owner's manual carefully.
  • I gotta check mine out, see if the load is hot all the time. But then we right back to square 1,......why not connect to the batteries,....meaning, whats the difference between the batt and the load terminals ? Ya got me curious now.
  • Hi Rich,
    Load terminals can be configured to operate a relay. They can be used to charge an additional battery. It really depends on the make and model of the controller.
  • Alright, I'm perdy ignorant on this "load" thing, only because I never hooked anything to the "load" terminals, or even touched them w/ a test light.
    But did I read that the load terminals are not hot as long as the voltage is hi ? And as soon as the sun (solar) quits charging and the voltage drops, then the load terminals get hot ? So they are there to connect a lite that will always be on whenever it is dark, and go out when the sun (voltage) comes up ??
    Correct this if this is wrong.
  • I missed the part about separate house batteries
    By all means, yes connect the fuse block or light circuit to the house batteries
    Use the house batteries connected to the solar as much as possible and avoid drain on the engine chassis battery
  • thanks...the LED lights aren't draining the van battery much so I guess Ill just keep them like they are
  • Load function uses battery
    The idea is solar charges battery during day
    Load function controls light etc.. that needs battery at night
    If your thinking you can get free power and save battery, it ISN'T GOING TO HAPPEN
    Solar only works during the day
    Even if you wired to controller, the only thing that would happen is power that would be charging the battery will goto lights during the day
    It's a lot of extra work for no benefit
  • Hi,
    You could, in theory do so, but then the lights would only work while the sun was shining. Just move the feed for the lights to the "house" battery bank.
    Another way around which may be even better is to get a device called an Amp-L-Start. That would charge the chassis battery from the house batteries.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
