BB_TX
Sep 17, 2021Nomad
The 2nd A/C is usually connected to the other hot leg. But it all comes down to how the rig is currently wired. The loading on the two hot legs should be fairly closely balanced. If, for example, the 1 A/C is on hot leg 1; and the water heater, converter, microwave, fireplace, bathroom outlet where a hair dryer would likely be plugged in are on hot leg 2, then it would be better to connect the 2nd A/C also to hot leg 1. Two A/Cs would pull less than 30 amps, well within safe loading for a 50 amp breaker.
On the other hand, if hot leg 1 had the A/C, water heater, and converter, then by all means the 2nd A/C should be on hot 2.
Look at your circuit breaker labeling and see (if you can) the current power distribution and then decide where to wire the 2nd A/C.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
