rockhillmanor
Oct 18, 2015Explorer II
Don't know were your sewage bay is located on your coach...but on mine the sewage bay was behind the rear duals. Blown rear tire took out just about my entire sewage bay. :R
That blown tire could have hit the black tank too. Which with what you described all it did hit. It would be hard pressed to think it didn't hit your tanks too!
You could have a real small crack on the underbelly of the black tank or even the y pipe coming out of it.
Check for hairline cracks around the screws that hold the valves on. That's where I found my leak from the tire blow out.
I found all it takes is just a few drops of water coming out of the black or gray tank to smell inside the coach.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
