Chris_Bryant
Aug 22, 2013Explorer II
You need this one- rated for 350 psi, made for the job. There are different end fittings on them- to go direct to the single regulator you need a 1/4 MPT thread (the other more common is 1/4" inverted flair). Use either approved pipe dope or yellow teflon tape made for LP.
Any RV place should have tons in stock, FWIW.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
