Bob_Landry
Aug 22, 2013Explorer
MEXICOWANDERER wrote:
The best HOSE you can get for direct pressure is called liquid motor fuel hose. It is MUCH MUCH stronger and safer than copper. Ends can be either crimped or "made up" 2-piece with swivel if necessary.
The best thing to use is a product that is designed to do the intended job and that use the appropriate hose and fittings properly connected. I've read post by people "rigging" propane systems with various hoses and clamps, but if you have ever seen the results of a propane fire or explosion, you might look at it a little differently.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
