This is from my batteries, the 12v DC system. With the ground wire off all my 12v equipment stopped working. From the negative terminal to the ground with all the fuses in I was getting 10 amps or so. From negative terminal to negative wire I was getting 0.75 amps. This seems clearly wrong from what I have read and sounds like a hot ground. However I'm confused, as I said above. I just want to be able to boondock without watching my batteries rapidly discharge.
Tim Czarkowski
Totaltravelers.com
