Dirtpig
Aug 04, 2016Explorer
Well i installed the car amplifier grade maxi fuse blocks today. It definitely made the heat issue go away so i am blaming the problem of hot fuse/fuse holder on the insufficient contact area for the amp load going through the small fuse and cheap fuse holder i initially used. I will attach some photo's. The idea of a circuit breaker is a good one and also one that i thought of but to buy non-hongkong breakers is pretty big money. I am still able to easily yank the fuses out if i want to disable solar charging for some reason, they are quite big and easy to grab onto. Thanks for everyones input.
Before:
After:
Before:
After:
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
