brulaz's avatar
brulaz
Hot water circulation pump
Was thinking of installing a 12-24V Hot water circulation pump between the hot and cold lines under our bathroom sink. The sink is farthest from the hot tank and it takes about 15sec of wasted water before hot water appears at the tap.
I would rather use a pump instead, tapped between the two lines under the sink, to recirculate the cold water from the hot water line over to the cold water line using a simple on/off button switch. I vaguely recall somebody here doing this?
Does this work? My main concern is that normal operation would somehow be affected. Like when drawing water from the cold tap, would hot water be drawn through the pump into the cold line, and vica-versa?
  • I looked into this also, check out the internet for several installations. One that sounded interesting was to put a T in the hot water line close to the faucet farthest from the HW Tank, run this to the circulating pump, and then run the output to a T near the HW tank with a back flow preventer there.
    You can use a manual switch or one with a short timer (just long enough to get hit water to to the pump). There is no loss of water in this system, but you don't need to run the pump to long wasting electricity.
    I saw several inexpensive circulation pumps on line, just make sure it can handle the hot water temp expected.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
