- DennisG9Explorer
smkettner wrote:
Get a small expansion tank after you replace the valve.
http://www.amazon.com/SHURflo-182-200-Pre-Pressurized-Accumulator-Tank
IMO every RV should have one.
Expansion tank is the way to go. In an RV you have a check valve on your fresh water line coming in so it creates a closed loop on the side your water heater is on. You are building excess pressure where in a stick house you have room for it to go to but in an RV it is a much shorter run. I added an expansion tank on mine and it cured the same problem your having. - wa8yxmExplorer IIIOk. as the water heats first the T-Stat should open, this is normal operation, and burners stops.. The water than cools, the T-Stat closes and it "Recycles"
Page 2: IF the T-Stat continues to heat the ECO should open, this will cause the lock outs you cite.. but should not blow the TPR.
IF it continues to heat, a plug in the TPR melts, when this happens it does not drip.. IT GUSHES, I mean Niagra Falls level Gushes. (Been there, Done that, not on an RV though) I mean Gallons per minute, Not drips per minute.
Dripping indicates a need to drain and flush the water heater.. (Routine maintenance) LET IT COOL, Remove drain plug, Install short 1/2 inch pipe (plastic, brass or metal) to extend flow past side of RV, if Suburban needing anode inspect anode and replace if needed. Flush using flush want (optional) and once drained close TPR and replace plug.
But check the T-Stats.
It is doubtful (Impossible on mine) that the dripping TPR is dripping water onto a circuit board and shorting it out. But I am basing that on MY water heater.. I've not seen yours. - RJsfishinExplorer
Houston Remodeler wrote:
T&P valves are easy and cheap to replace. I'd start there.
Mine wasn't easy. First of all I had to make a special tool to remove and install. And 2nd, it was super tight,..... after 2 trys, I went for broke, figured on a new heater, but got lucky.
And if I recall, after I made the tool, I found one on line made for that purpose. - RJsfishinExplorer
X 3 !! - Get a small expansion tank after you replace the valve.
IMO every RV should have one. - Old-BiscuitExplorer IIIAtwood G6A-6E ------ 6 gallon 'gas' only with electronic ignitor
Uses a front mount t-stat/ECO
T-stat OPENS at 140*F and CLOSES at 110*F
ECO OPENS at 180*F and CLOSES (auto reset) at 150*F
Normal operation ECO should always be CLOSED
T&P Relief Valve
OPENS on HIGH Temperature 210*F
OPENS on HIGH Pressure 150# ---resets 125#
IT is the fail safe device........normal t-stat fails then ECO, ECO fails then T&P
Depending on which tank was used T&P can be 1/2" NPT or 3/4" NPT threads. Available at most any hardware store
'FAULT' Light (Red light ON/OFF Switch Panel) Comes ON:
IF propane fails to light off and PROVE (no return signal to circuit board ---so voltage on gas valve gets dropped closing it)
IF 'Thermal Cut off' trips (190*F blow back ------dirty/obstructed combustion chamber)
IF ECO OPENS - Houston_RemodelExplorerT&P = temperature and pressure, which are the two reasons the valve will automatically open.
Read all about them - Yes, zero ohms for the ECO when operating under normal conditions.
The thermostat will open(no resistance) at the set value, roughly 130 degrees. - willi4ndExplorerPRV's weaken and calcium builds up, replace with correct one. Match specs on ring.
- groundhogyExplorerRelief valve was tripped and then due to age didn't fully spring back
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
